Minolta Maxxum 300si 35mm SLR Camera Logo
I can't shut my Minolta maxxum 300si off. How do I clean or repair the On/Off switch?
The switch will turn it on< but not Off
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Jun 29, 2008
SOURCE: minolta maxxum 300si 35mm camera battery
It takes either: Energizer 475 or Duracell 245........if camera still will not fire, your camera has a problem. www.flcamerarepair.com
Anonymous
  • 480 Answers
  • Posted on Jul 09, 2008
SOURCE: minolta maxxum 300si (Filters?)
Hey sunnibeach4,
On SLR cameras the filters are attached to the end of the lens via threads inside the end of the lens barrel. Without knowing exactly what lens you are using I can't tell you what filter diameter you need but most lenses list that information on the inside rim of the front of the lens. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Anonymous
  • 14 Answers
  • Posted on Jul 31, 2008
If it has a Minlota mount, yes!
Anonymous
  • 14 Answers
SOURCE: MINOLTA MAXXUM 300si
Try www.flcamerarepair.com No chg. for ests.
Anonymous
  • 667 Answers
  • Posted on Jan 05, 2010
SOURCE: I have a Minolta Maxxum 300si. I took the film out
You will have to open the back and may lose a roll of film, but it will be an easy way to check the camera for a possible mis-load of the film.
How do I get the battery to work when it is a new battery? The battery light keeps blinking
Blinking battery is sign of transport problem. Probably failure of the transport gear unit I the bottom. Minolta is out of business so no parts. Some tech do a fix on this, you would have to call your local repair shops. This is too complicated for a novice.
Minolta maxxum 300si (Filters?)
Hey sunnibeach4,
Sincerely,
Allan
Go Ahead. Use Us.
Minolta maxxum 300si 35mm camera battery
Going through the airport...
Try removing battery and then re-install. If that doen't help, try www.flcamerarepair.com They do not chg for ests
Top Minolta Photography Experts
ZJ Limited
ZJ Limited
k24674
Are you a Minolta Photography Expert? Answer questions, earn points and help others
