Televison & Video Logo
Anonymous Posted on Dec 15, 2011
I have a Thomson Scenium 67" and just turn off by
TV Doctor
Level 3:
  • Master 373 Answers
  • Posted on Dec 15, 2011
TV Doctor
Master
Level 3:
Answers
373
Questions
Helped
92969
Points
1011
Can you please send me the model number. I will be better able to assist you. And another more detailed description.
  • 7 more comments
  • Anonymous Dec 15, 2011
    I don't know what the model number is but here are the numbers i got from the back of t.v. Type: 502D,CC21AU or AR5650879 or RP00110810
  • TV Doctor
    TV Doctor Dec 15, 2011
    I hate to bother you again but it should say model and then the number. I cannot proceed without the model number. Please look again
    Hi there i did look behind the tv again it seen to have no other numbers there was this one. BK17TH I hope you can help.
  • TV Doctor
    TV Doctor Dec 16, 2011
    You may have a bad lamp. There is an access door to the lamp usually on the back of the set or behind the front grill in some models. Pull the lamp and housing out sometimes held by screw(s) and look at it to see if the glass is shattered inside the lamp. Also look for cloudy effect in the lamp or bubbling of the glass at the base of the center glass stem in the middle of the lamp. If it is bad you will have to have the part number from the lamp or the model number of the tv and go to www.pureglare.com for price and availability.
  • Anonymous Dec 16, 2011
    If its not the light bulb is there anything else i could look at. Cause the red light on the t.v flashing 3 times and then stays red. so if i check the light bulbs and that is not the cause, do you have idea what else that could be causing the problem.
  • Anonymous Dec 17, 2011
    Hi there i really want to get my t.v fixed i want to know how to do. I pay the price for your help please.
  • TV Doctor
    TV Doctor Dec 17, 2011
    Is the fan coming on? It could possibly be clogged with dust. It is difficult to determine what is wrong without the model number but I will try my best. Just keep in touch. I was not on the during the day today. And if you did get the lamp out you have to be sure it is plugged in all the way and the lamp door is in right. Could you give me another description of the problem to help figure what is wrong please.
    When it first turned off it was just like you had turned off buy remote, but no one had the remote. And then we try'd to turn it on again and the red light will not turn green and it flash 3 times then stays red. And its a 61" Thomson Scenium and it has three light bulb under the screen in between the speakers i hope that will give you some idea. Thank you so much.
  • TV Doctor
    Now that you mentioned it has 3 tubes that is different. And when the light flashes 3 times that only means a bad flyback transformer. It is the black component with the large red wire coming out of it and going back into the set. It requires experience to change it (unsoldering and soldering). And the last time I tried to get a flyback it was difficult to find as RCA started discontinuing these. But you might try getting all the numbers from off the flyback and call MCM electronics or Encompass Parts. Encompass number is 1-800-638-3328. You will need the proper model number from off the back of the set for them to see if they have it anymore. I hope this helps
Thomson scenium 30lcdb03b manual
this tv is old now and thomson no longer have them in stock
the menu on the tv is very good and should cover all conections and inputs and tunning
1helpful
Hi i want to ask about a lamp that related to thomson tv thomson 61 dsz 644 dlp hd tv lamp what is its price ?
http://cgi.ebay.com/LAMP-THOMSON-SCENIUM-61DSZ644-RP-HD-DLP-TV-/270697798709?pt=LH_DefaultDomain_205&hash=item3f06d89c35
19helpful
Tv not coming on just red light flashing on and
thomson scenium jw 611s not coming on just red light flashing on and off at front of tv
My thomson scenium goes straight to standby when i turn it on. it was working fine, and i turned it off on the set itself. nothing works using the remote either
Tries by reset it unplug and replug,clean ur IR in ur remote and change the batteries,also clean IR in the tv also.
Thomson scenium LED error code 45
When i turn it on red light flashes 3 times then 1 time, this keeps on repeading, no sound, no light
MY THOMSON SCENIUM BOARD IS DAMAGED!!
CALL 01245392539 AND THE UK THOMSON SUPPLIER WILL BE ABLE TO TELL YOU IF IT IS STILL AVAILABLE
THOMSON SCENIUM 44RW65US Red light flickers
i have the same problem. i have to switch it off at the mains 5 times b4 it comes on
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
