I am not an expert user so I don't know much about this but needing to contact a forum to solve a problem I learned the Java programme and Java Script that causes problems when it doesn't work are two different things.
Java Script, they told me, is not a standalone programme but a part of the Windows operating system. I can't remember the details but I had to open the control panel and somewhere in there had to "enable script".
I hope this helps.
SOURCE: Windows Installer 3.1
I have found a web site with a procedure to repair your Windows Installer... http://wiki.williams.edu/display/docs/Windows+XP+Repairing+Installer+Service Perhaps when this problem is fixed all the rest will fall into place.
SOURCE: Nero 7 Uninstall
Get clean tools here, it will take it out for you:
http://www.nero.com/enu/downloads-cleantools.html
Let me know how you make out
thanks.
SOURCE: installing java applications and games in razr v3i
download your .jar files to ur pc....
then copy and paste them in the kjava folder on your mobile.....
then go to games & apps and click menu and select switch storage device...
when you switch ovr to memory card ul find "Install New" click on that and u shud have no othr problem....
was it helpful????
let me know
SOURCE: Installation stall with 39 minutes remaining
Sound like the memory then. As we all know its a process of elimination. That said, I've never been able to do a clean install with a USB keyboard and Mouse. I always reverted to a PS2 keyboard and Mouse as those drivers usually need to be installed separately was back from the Windows 95/98 days, but that doesn't mean you shouldn't be able to do so with XP.
Your OEM disk could be bad. All you need is the Product Key, so you could download an iso image and put it on a drive to install from there. All this you probably konw.
Anyway, you are doing everything as I would have done. You should join us here at Fix Ya and become an Expert. Its stimulating to help out with this board as it is extremely challenging, much harder than fielding a phone call.
Good Luck, but you'll do fine.
Worldvet
SOURCE: Activating fone for java applications
ebuddy is not as good as some of the other apps I have used for the w910i. I would reccommend using numbuzz or queep. Just search for them on google or this specialist mobile java app website:
www.getjar.com
Please rate me! :)
