Broiler won't shut off with out shutting off circuit breaker. Stove top keeps working okay, but broiler lights up as soon as oven is switched on and will not turn off with control panel. No error messages are set.
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
BROILER WILL NOT SHUT OFF AND HAD TO FLIP BREAKER TO TURN OFF.
