Estate TEDX640JQ Electric Dryer Logo
Posted on Oct 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My broken belt
I ordered the belt and will figure out how to do it. I just replacedthe plastic "do-hickey"( that quickly I forgot what the part wascalled) that broke in my washer 2 months ago that caused that to stopspinning. That was a pain but I got it done. Interesting how I lost thespinning component both in my washer and dryer within 2 months of eachother....or more like a headache!
Any helpful hints once I am ready to operate?....it is an Estate Dryer by the way
Terry Schneider
Level 2:
Novelist:
  • Expert 177 Answers
  • Posted on Oct 04, 2008
Terry Schneider
Expert
Level 2:
Novelist:
Answers
177
Questions
0
Helped
67238
Points
302
Make sure the dryer cylinder spins freely once you have the front panel back on.
Yes replacing the plastic "do-Hickey" I believe its called a coupler that connects the motor to the transmission is a pain, I think the cabinet again is the worse part to fit back on.
You are now a do it myself and saver, However be SAFE! once you open an appliance up you are exposed to sharp edges and electrical components, so make sure you unplug the appliance first.
Left screws in the back of new Zanussi washing now it wont spin
It must have broken some plastic off inside or may have jammed the belt mechanism. Check the belt and suspension/mounting.
1helpful
My hood release handle (1996 Fleetwood) has come off, not broken off. I can NOT figure out how to reattach it in order to pop the hood. Help??
Generally speaking, the handle has a pivot point where it pulls against to be able to pull the cable.
You should be able to pull the cable with a pair of pliers for the time being.
You might take a look at a junk car to see how it is mounted.
Need a new belt for a bissell lift off revolution turbo
Hi Dale, sorry to hear the belt has broken. Now is a good time to order filters for orders that are $30 or more receive free shipping. Here's a quick link to ordering one.
http://www.bissell.com/parts/?sc=search2&searchtext=3760
17helpful
4answers
The belt broke on my my SHARK Model V15Z and Euro Pro hasn't responded to my request for a new belt w/ directions as how to effect repairs.
Well it's actually not so bad once you realize where they hid the screws. Gently pull outwards on either side of the housing that surrounds the brush and vacuum.There are no screws for this piece it simply snaps off and on. Once this piece is removed you'll see two phillips type screws on the side where the removable hose attaches. Remove the two screws and pull off the molded section they keep in place. The brush will now come off revealing the rotor that the belts slips over. The belt is placed over the rotor and the brush cylinder in a figure eight. Reassemble and your ready to go. Now if Shark will only help customers locate a replacement belt you may find this info useful.....
Kenmore dryer 70 series
on the panel that you were putting on check to see if there is a burn mark. then check the wire that you hit. fix any broken wires. and also check your fuses or circuit breakers.
2answers
Brushes won't turn
Sounds like you have broken belt. I had the same thing happen, Got replacement belts, but can't figure out how to get the smaller belt back on. There two larger belts - one on each end of the brushes under the clear plastic covers. On the left side there a single silver metal gear, but nothing to hook up the other end of the small belt to drive the brushes. If you take yours apart let me know how to hook up the smaller belt.
Thanks,
David Wood
2answers
Whirlpool Duet Stackable Dryer
check belt ..there is a broken belt switch also ckd thermal fuse .this is the white do hickey behind the lower panel behind the lint screen housing if a vent problem occurs this fuse will blow and unit declines to operate
Agitator won't move
Sounds like the belt is slipping or broken.
you may be able to see it from the bottom
tilt it back.
Broken Belt Trouble and also plastic piece with spring has a broken part
you can order new parts through Bissell.com web site they are very hepful
Top Estate Dryers Experts
Paul Carew
Jorgie  the...
Jorgie the...
Are you an Estate Dryer Expert? Answer questions, earn points and help others
