Durabrand BH1304D 13" TV Logo
Anonymous Posted on Dec 13, 2011
Dish network remote access codes - Durabrand BH1304D 13" TV
Level 3:
  • Durabrand Master 17,130 Answers
  • Posted on Dec 13, 2011
Durabrand Master
Level 3:
Answers
17130
Questions
0
Helped
3635324
Points
52372
3answers
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
I need to find out what the remote access code is for this device so I can program my dish network remote
Hello! My name is Becki Barned, and I am with DISH Network. I have provided some steps to program your remote. Because I do not know the model number of your remote, there are a few codes to try. I hope this helps!!!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
764
672
777
Becki Barned
DISH Network Customer Service
Can not program my Dish network with remote RMvz320
Hi my nameis Mike Houston of DISH Network and I see you want to program the Sony remotewith the DISH Network receiver. We do not have the codes for universal remotesto our receivers, the best thing is to have a DISH remote then you can havefull access to the menus and functions of the receiver. I will leave the linkwith you to help setup that Sony remote, http://esupport.sony.com/perl/select-system.pl?PRODTYPE=32&DIRECTOR=RCODES.If you have any questions please e-mail me at [email protected].
I just programmed my dish #2 remote control to a tv. The remote is not working. I cannot access the guide menu "etc". What do I need to do? This is a second tv and the remote worked just fine before....
It sounds like the remote would need to be programmed to the receiver itself. It may have lost it's programming when the TV code was put in.
To program remote to Satellite:
1. Access System Information screen.
2. Note the # on the bottom where it was Secondary Remote Address.
3. Hold SAT until all buttons on top of the remote light up.
4. Let go and while it's blinking enter a number between 1-15 and press #
5. Press record 3 times and test remote.
Tommy Faust
DISH Network
Are your under cabinet mounted TV's Dish network compatable? If so what is the code for configuring the Dish remtoe to access the TV. It is not necessary that the remote control the DVD area.
We would be happy to help you with getting your DISH Networkremote to control your Venturer TV. We currently do not have any codes for the brand Venturer so we would need to perform a power scan. A power scan will scan your DISH remote for any codes that will work with your TV. Here are the steps for a power scan:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
I have Dish Network and remote #1 and 2...the TV for Remote #2 has now changed but the remote will not work...I replaced it with an Olevia Flat Screen (used one) 32in LCDHDTV Model 432-S12 but cannot...
If this hasn't been resolved, I do have some steps that will help you out. The link below will walk you through a power scan, which will program the remote to the tv. At that point, you will be able to change the channels on the tv with the remote.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
3helpful
Remote Control access codes for Samsung BD-C5500 for use with Dish Network
We would be happy to help you with that. Here is a list ofcodes that should address your DISH Network remote to your Samsung Blu-Ray Player: 506, 755, 807, 524, 534, and 591.
Start by pressing and holding the DVD/VCR button located on the top of the remote until allthe mode buttons at the top of the remote light up, then release. Use thenumber buttons to enter one of the codes for your Samsung Blu-Ray Player, then pressthe pound (#) button. If the code entered is valid for the remote, the modelight flashes three times. To check that the code works try several differentfunctions on the remote to make sure it will properly operate your Blu-Ray Player. Keep in mind that some codes may not be compatible with it.If this is the case, please try the other codes listed for that device untilyou find one that is compatible with your equipment. We hope this helpsand thank you for being a valued DISH Network customer!
Phillip Chang
1helpful
Need code for 32in.olivia tv
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, TiVo’s, DVD, Blu-Ray or even HD- DVD players. The learning remote is available at 866-965-3842
Dish Network Remote Codes 506 or 127
could try Dish Network..Remote Codes 506 or 127
Satellite TV Systems Dish Network Remote Codes 506 or 127
2helpful
2answers
Code for trutech
dish network remotes dont work with very many tv/vcr or tv/dvd combo units
Top Durabrand Televison & Video Experts
matt martin
matt martin
ZJ Limited
ZJ Limited
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
