Mode "A" (Test Mode)
1. While holding down both DPF INHIBIT switch and the parked regeneration switch, turn the key switch to "ON" or "START" position.
2. Mode selection display is indicated on the LCD.
3. Press the parked regeneration switch and the mode indicated on the LCD is changed.
4. If "A" is indicated on the LCD, press the parked regeneration switch for more than 2 seconds.
5. Test mode is selected.
6. If parked regeneration switch is pressed, the display item is changed.
7. Turn off the key switch to finish test mode.
Mode "b" (Error Information Clear Mode)
1. While holding down both DPF INHIBT switch and parked regeneration switch, turn key switch "ON" or "START" position.
3. Press the parked regeneration switch and the mode indication on the LCD is changed.
4. If "b" is indicated on the LCD, press the parked regeneration switch for more than 2 seconds.
5. Error information Clear mode is selected and the expression "PUSH" is displayed.
6. Press the parked regeneration switch for more than 2 seconds.
7. The expression "OFF" is displayed.
8. Turn off the key switch.
Be sure to clear error information by performing this procedure after servicing is finished.
A Nokia N70 can be unlocked safer and easier using unlock code. An unlock code for a Nokia N70 can be acquired from http://www.unlocking4u.com/nokia-n70/rs6wp9/ at affordable cost. Here are the steps for unlocking a Nokia N70, 1 - Switch on your Nokia N70 without any sim card. 2 - Don't bother as to what is displayed on your Nokia N70. 3 - Compose #pw+CODE+1#. 4 - The Nokia N70 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N70 mobile phones locked to the network Fido or Rogers in Canada follow these instructions : 1 - Switch on your Nokia N70 without any sim card. 2 - Don't bother as to what is displayed on your Nokia N70. 3 - Compose #pw+CODE+7#. 4 - The Nokia N70 would then display the message "SIM Restriction Off" and will be unlocked!
It is a common problem of NOKIA N70.
Switch off your phone.
Remove the battery & sim card.
After some times (30 minutes) set them again & switch on.
Leave the phone for a while it will automaticly in order.
problem switcher
service auto start problem: services disabled appeared on my n70
