Its a Kodak easyshare M580 and I was looking thru my pictures and it froze on me , now it wont do anything. What am I to do, It's not even a year old.
SOURCE: my kodak easyshare M580 wont download onto my
DEAR SIR,
The best way to download pictures from your camera to your computer can be done by two means....
1.INSTALL THE SOFTWARE C.D GIVEN ALONG WITH THE CAMERA IN YOUR NOTE BOOK....
THEN SWITCH ON YOUR CAMERA AND CONNECT THE CAMERA TO YOUR P.C VIA U.S.B CABLE,AND WAIT FOR FEW SECONDS FOR THE P.C TO DETECT YOUR CAMERA,ONCE THE CAMERA IS DETECTED IT WILL ASK YOU,WHETHER TO COPY YOUR CAMERA IMAGES TO YOUR P.C
2..Remove the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
thank you..take care
SOURCE: my kodak m580 camera fell,
I'm sorry to bring you bad news, but the mechanism that extends the lens for focusing has become broken, or the pins have popped out of their tracks, or the motor or gears have broken. This kind of problem is very common, and comes under the heading of "Lens Errors". I have searched around the Internet for news of people addressing this problem, and this is such a common problem that someone has written a blog just addressing this one error. You can read it here - it describes it far more completely than I ever could!
SOURCE: How do I get my
Press the MENU button. Use left/right to select the Setup tab. Use up/down to select the ninth item.
SOURCE: how do you stamp date
1. Press the Menu button.
2. If your camera displays a menu with tabs at the top:
a) Press the Right/Left buttons to highlight the Setup tab.
b) Press the Down button to highlight Date Stamp.
c) Press the OK button to add the date stamp to new pictures.
3. If your camera does not display a tabbed menu:
a) Press the Down button to highlight Date Stamp.
NOTE: Depending on your model, Date Stamp might be within the Setup choice.
b) Press the OK button to add the Date Stamp to new pictures.
SOURCE: I was taking pictures of
TRY CHARGING THE BATTERIES EXTERNALLY .THIS MIGHT SOLVE YOUR PROBLEM.
REGARDS.
PLZ. RATE THIS
