The 2200 error code indicates that the scanner has stalled. That's why you're not able to make a copy. Please refer to this article on the Lexmark website to fix the problem: 2200 Error on the Lexmark X7100 Series All-In-One
Should the error continue to display, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
According to the Lexmark site the 2200 error is a jam, possibly the scanner. Try unpluging the power at the printer, remove the paper, and see if there is any paper stuck in the unit. Another possibility is the cartridges are messed up. If you don't find paper stuck, remove the cartridges, and reinstall the color one. If the error goes away, the black cartridge is possibly bad. Another problem you can't fix, which is the scanner glass cracked. In that instance or if the cartridge swap doesn't work, contact Lexmark to fix the unit.
there is a one white patch sensor on the fixing film, if this patch sensonsor can't read by fixing unit. machines will show E007 error because of fixing film broken.
i have installed the cricket revolution game on windows 7 but when i launch the game its show the 'cricketrevolution.exe has stopped working' and 'could not copy' error message .. so pls tell the solution plsssssssss
Here's an article in the Lexmark website on 2200 Error on the Lexmark X7100 Series All-In-One. Just click on this link for instructions on what to do: http://bit.ly/deHk7F. Hope this helps but if all else fails, don't hesitate to contact Lexmark Technical Support for further assistance.
Restart/Start/Check status Printer Spooler: 1. Click on Start button 2. Choose Run 3. type in “Services.msc” without the quote marks 4. Enter 5. Scroll to Print Spooler – should show if spooler is running 6. Select 7. On left side, click start or restart 8. Or double clidk then set start up to auto and click apply and OK
