Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
Dave Hixson Posted on Mar 08, 2017
When I first installed the he220 it worked fine. Furnace kicks on and the solenoid will click off and on. You could heaar the water running through and the pad would get wet. Had it set on 45% and my humidity gauge in the house read 45%. About a month after installation I noticed humidity level in house down between 30-35%. I checked and even though the humistat was set a 45% and humidity in house 35% the solenoid wwas not clicking on and off and the drain tube was dry. I messed with the humistat dial and turned it up to 60% and it clikcks off and on a bit(not has much as it used too) sometimes real short clicks. Once the furance kicks off, but the fan continues to run for a couple of minutes, then the unit starts clicking off and on a lot and for longer periods of time and allowing a lot of water through??? My unit is rated for a home bigger than mine. Does this sound normal? Can it only keep the house at 35%? If I turn it way up shoudn't it run a lot? Even if I turn it to
3 Related Answers
Anonymous
  • 30 Answers
  • Posted on Mar 04, 2008
SOURCE: Install HE220 HoneyWell , humidity not increasing in the house.
You can try installing the water line to your hot water if it is installed on cold line for more humidification. You should make sure your humidistat is up line 6" @least from humidifier for proper humidification measurement.
Anonymous
  • 8 Answers
  • Posted on Feb 04, 2009
SOURCE: Water keeps running to Honewell 360A Whole House Humidifier
You may need to replace the valve that is wired to the furnace that controls the water flow
Robert
  • 1036 Answers
  • Posted on Jan 18, 2011
SOURCE: We had a honeywell humidifier
Yes when you turn the dial on the humidistat 24 volts gets sent to the solenoid valve and it will click open and allow water to flow through it.
Solenoid valve switching continuously he220
I would think it would need to switch on & off to control the water flow through for correct humidity..
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
No water flow through solenoid
The water flow through the humidifier is limited/controlled by an orifice. This small opening can easily clog. After disassembly use a small wire to clear the debris trapped in the small hole,
Hope this helps?
I hear no water draining from my heathy soluions lennox humidifier just put in a new filter
None leaking? Try removing the cover, and manually cycling on the controler switch? Does the solenoid click on, next to the humidifier (the unit with the water line running through it, with wires coming out of it)? If it does click on, is water running down the water pad? It doesn't necessarily drain water when it's working correctly. All of the water SHOULD be getting evaporated into the air return duct.
If it's clicking on, but no water is running out, you should check the water supply saddle valve and make sure it wasn't turned off during servicing.
If it's not clicking on, you should test that you are getting voltage (12v-18v DC) to the solenoid. If you're not, check all wiring connections and make sure they're tight. If you still don't get power, you have either a problem with your control unit/humidistat, your DC power supply, or the control board on your furnace.
Jan 06, 2013 • Humidifiers
Honeywell he220 humidifier problems
If it's not clicking on, you should test that you are getting voltage (12v-18v DC) to the solenoid. If you're not, check all wiring connections and make sure they're tight. If you still don't get power, you have either a problem with your control unit/humidistat, your DC power supply, or the control board on your furnace. You may need to call a HVAC technician at that point, depending on your comfort level/skill level in that regard.
When you say the solenoid "stays hot" do you mean it's physically hot to the touch? Hotter than the water lines running into it?
If the solenoid is getting hot, it probably has a bad coil, and if you continue to operate it, you will probably burn up your DC power supply.
If you're getting voltage, you have water pressure, and the solenoid is still not opening, replace the solenoid.
Wire Honeywell HE220 to N8MPN/L, *8MPN/L furnace control board
HI
I have similar isssue with HE220 but in my case the water run through all ththe time, even when unplugged from the power outlet.
Would that be solenoid issue?
the unit run fine for last season so the wiring is fine.
Any ideas would be greatly appreciated.
Water runs when furnace is off, but stops when furnace is on.
the 760 humidifier does not need a transformer wired externally. the 760 has its' own 24v transformer inside the fan compartment. this transformer will provide the power to enrgize the water solenoid as needed. it sounds like to me the additional trasnformer is hot all the time. when the furnace comes on, the unit gets power and the internal transformer is cancelling the power from the external transformer. this would explain why it quits running when the heat is on. since the external transformer is hot all time, when the heat shuts off, the solenoid is getting energized by the external transformer. to make this run correctly, you need to get rid of the external transformer. leave the humidifier high voltage wires hooked up so they are only hot when the furnace runs. if you have a humidistat that has a r and c terminal, you will need to wire these directly to the r and c on the furnace control board and move the switch inside the humidistat to "power". make sure it is not on "bypass". then wire your 2 brown wires from the humidifier to each of the "h" terminals on the humidistat. if you have a humidistat that only has 2 terminals, wire one brown wire to each of the terminals. this should allow it to run properly.
2answers
Water not running through humidifer
Mine had the same problem no water through the solenoid. It turned out to be the little adapter with the needle hole on it, attached to the solenoid on the intake side. It was clogged, cleaned it out and works great now.
Top Honeywell Humidifiers Experts
Paul Carew
NOEL
NOEL
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
