Good day!!!
Before I answer your question let me clarify something..
To test the remote please use a digital camera..How? place the shot to infrared of your remote then look at the screen of your camera after that press any button on your remote and look if the IR sensor lights up..
Please answer all my clarifications for me to diagnose the exact problem..Because replacing of IR sensor on TV is difficult..
Thank you for using fixya and choosing my service..
I'm sorry you didn't read my initial communication with Fixya. After 5 years of normally functioning, several different remotes programmed for the Vizio L37 ceased functioning. The manual "buttons" continued to function normally. If this indicates the TV's IR sensor unit needs replacing (It is available for under $20.00), I need to know how, no matter how difficult. Gerald Moss
Good day Sir Gerald Moss,
Sorry for the late reply..
Please follow the instruction below to replace the TV receiver sensor..
1. Open the back cover of your TV by unscrewing it using Philip screw driver.
2. After that all parts on the LCD TV revealed such as power supply board,main board inverter board etc.
3. Then try to look at the bottom side of the TV that usually locate the receiver sensor..It is usually together with the power indicator (red/green) LED.
4. There are screws on that board please remove it to pull out the receiver board assembly.
5. Before you decide to replace the receiver sensor on your TV please try to clean it with soft cloth and also the plastic protector..
6. After you clean the sensor and protector and the problem persisted that is the time to replace the sensor.If you have a sensor assembly its better if not you need to replace the sensor only.
7. To replace the sensor you need a soldering iron and soldering pump to pull out the sensor..
Hope it helps..If you have more queries and clarifications please reply to this tread.
GOD BLESS!!!
The IR board is also together with the buttons on your front TV..
Also I will search for the service manual for you!!!
If you need a service manual for the future used also this service manual help you to locate that parts on the last page of this manual..It will locate @ # 2 on the parts list also include the part # in case you search the parts for online purchase..
This the link:
http://nationalservicealliance.com/visio...
Sir I want to follow up what happens on your TV..
If you have more clarifications and queries please let me know..
And if you satisfy my answer please rate my answer to keep my account active..
Thank you very much..
