I have a KODAK CD14 and i have this camera not working properly since when i dropped it into water. Technicians say that this wont work never again if the firmware isnt working out. And unfortunately it is the case to be afraid as it has crashed the firmware inside it. So therefore please help me with this to fix my camera. Provide me the link or URL where i could get the firmware of CD14 KODAK EASYSHARE. REGARDS.
SOURCE: Kodak easyshare camera not transfering photos
My kodak easyshare camera will not transfer my photos to the computer. Everything is plugged in and the camera is blinking but nothing is happening. Please help. I checked the connections, they are fine.
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
Yes you are. My wife denied that she dropped in the sand but I found a list of photos that she wanted to print on a post-it paper in the cover and it had sand all over the sticky part. Used the pressure air spray to clean the rings and it is back to life. Well It worked but there was some problem during zoom in&out, so I spray the rings while zooming and out and that cleaned it. I hope I don't have to open it to clean the mechanism. Thank you.
SOURCE: My Kodak Easyshare M1063 won't turn on
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem and this fixed it, it seems to be a common problem.
SOURCE: My Kodak EasyShare software is not working. Tried
You can download and install the latest version of Kodak Easyshare software (v 8.0) at:
http://www.kodak.com/global/en/service/software/easyshare/en/dln_ekn026079.jhtml?pq-path=4509
