Hi. My bets are on the power board. Replace that and you'll be good to go.
When you have the back off check for any fuses on the power board. Maybe you don't need to replace the board. Good luck
1. Check all cable and input connections are secure & all are tightly connected.
2.Check power cords and also power outlet , if possible try to unplug and
reconnect . A replacement of power cable or use another power outlet is another
good option.
3. If you are sure that power is reaching your TV(check it out with a test lamp that both neutral & ground or earthing is functioning, i.e. the test lamp glows) then probably the power board needs replacement.
Having the same issue . Were you able to get yours fixed.?
