The dot is on the same area every time. I have tried switching lenses but the dot is still visible. By using the flash, the dot is somewhat faded. W/o the flash, the dot is very prominent.
It appears you have a speck of dirt on the photo sensor.
Turn the camera off and remove the lens. Carefully lift up the mirror. Using a blower brush, blow air at the shiny rectangle in the back of the interior. DO NOT USE COMPRESSED AIR!!! Use a manual blower.
If this doesn't do it, you may have to use a sensor swab to clean the sensor. If you don't want to do this yourself, any good camera shop should be able to do it for you.
Testimonial: "Thanks k_akima that solved the problem."
SOURCE: Spot on photos
I have one as well. I believe it is coming from the flash. See if it only happends with the flash. If so check to see if the flash has some burn areas
