My grandmother's go chair has become unresponsive. The controller stays completely blank whether the charger is plugged in or not. Before this the batteries were not charging correctly (so we replaced the batteries), but now the chair won't even turn on. The only service center I know of in the Detroit Metro area is talking almost a month before it may be working and she can't wait that long - this is her only means of moving outside of her room. My assumption is that the controller will need to be replaced (Monster Scooter Parts has the controller listed for $549+ship.), but is there any kind of diagnostic I can do to be sure? I have a multimeter, but no pinout or other technical information.
I have a Golden Alante power chair. The on/off switch will not operate after I got caught in a rain storm. I took the joystick apart and cleaned the contacts with alcohol but it still does not work. I can short across the two terminals on the circuit board to turn it on. The rubber buttons have what I assume is some sort of carbon infused contact to short across the two gold color contacts on the circuit board. That did not help. Does anyone know of a more effective cleaner that might help rejuvenate the contacts? HELP!
Hello,download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 as a PDF File to view via an Adobe Reader.This should be a great help to you.Hope this has helped,i am disabled myself.Colin.
I suggest you print this out and keep it handy.
Locking/Unlocking the VSI
The VSI has a feature that enables you to
lock your power chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
NOTE: If the above procedure fails to either lock or unlock the VSI, contact your authorized Pride Provider.
This is the procedure to unlock the controller on a Pride Jazzy:
To lock the VSI:
To unlock the VSI:
Lock Mode
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple side to side.
Hope this helps
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
To unlock the VSI:
Good Luck
mi mobility
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
