Test all leads that attach to your hard drive including electrical extensions SATA / IDE the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working might be getting hot check the CPU make sure it has thermal paste and dust free secure seating also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope this helps
during the boot up process for a short time you will see a certain key to enter set up
press that key to enter BIOS scroll to PnP/PCI configurations the default is disabled
select enabled to reset configuration if you have installed a new add on and it has caused a serious conflict that the operating system can not boot
start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive
hope this helps
