Watches Logo
Posted on Dec 08, 2011
I need a band of a nautica N13530
The band can be of leather or resin, where can i faund it?
4 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 25, 2009
SOURCE: discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Anonymous
  • 2501 Answers
  • Posted on Jan 26, 2010
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Testimonial: "THANK YOU"
Anonymous
  • 548 Answers
  • Posted on Jan 21, 2011
SOURCE: Hi I have a
You can go directly to Nautica Australia. Here is the exact link: http://www.nauticawatches.com/service or use: http://www.nautica.com/helpdesk/index.jsp?display=store&subdisplay=contact to order the resin band\
I hope this helps you.
If you need further assistance, or have further questions, just leave a comment. Thank you for using FixYa. Cheers
RoedeOrm
  • Posted on Aug 17, 2011
SOURCE: Hi , I need a
You can take any leather band but the wide must be 22mm. I´ve a diving band from casio watches since 4 Jears. It´s still ok.
Hello I need a replacement band for Nautica wach N17524
FOR NAUTICA BANDS GO TO:
GO TO: http://www.ebay.com/sch/bluss_929/m.html?item=221597748969&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
3answers
Neeed a replacemet strap, band or metal bracelet for Nautica N19558G Black dial Resin Mens watch
You can get it from Authorized Dealer of this Company. If it has nothing to do with it's warranty, any alternative shop will be an economic option.
Need a 30 mm watch band
NAUTICA REPLACMENT BAND http://www.ebay.com/sch/bluss_929/m.html?item=221597748969&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
2answers
I need the wristband of my NAUTICA n13530, Im From Colombia, how much does it cost?
1helpful
4answers
I want to buy wristband for my nautica n 135 30
This is a proprietary fit band. Only the manufacturer carries the band. You will want to contact Nautica's watch department customer service directly at:
[email protected]
Nautica watches are produced by Timex, so this is the correct email.
Specify the model number, serial number, band number (if you see one on the reverse) and request price and availability for the band.
If the band is not available, they may be willing to offer you a new watch as replacement.
2answers
Hi , I need a leather band for my nautica a 23095
2answers
3helpful
2answers
Where can I buy a new White Resin Nautica watch band for Nautica N14537 Wrist Watch. Armando Mendizabal [email protected]
5helpful
2answers
I need the wristband from N13530
I NEED A WRISTBAND FOR A NAUTICA N13530
18helpful
2answers
Discolored white nautica watch band
Top Nautica Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Nautica Watch Expert? Answer questions, earn points and help others
