SOURCE: Carsear Straps
I believe page 3 is what ur looking for. I have done this SOO many times, they get soo dirty soo quick!! Good luck and be safe!!
http://www.elitecarseats.com/assets/product_files/instructions/Eddie-Bauer/EddieBauer_3in1_manual.pdf
SOURCE: Putting carseat back together after washing..
Here's a manual:
http://www.coscojuvenile.com/usa/eng/DJGFiles/ProductDocuments/43583614D.pdf
Hope this helps!
SOURCE: i need to put the shlder/lap strap back in
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
SOURCE: straps back on after washing
I am dealing with the same problem. After looking at product photos, it appears all harness straps go out from the back of the pad thru the same opening. This is not fun. I would not buy this again. :-(
