Have replaced element (the original had an expanded area in the tube, indicating a hot-spot>failure had occured) - but srtill fan oven does not warm up. Now realise the 'exposed' grill element in the oven does NOT work either, while the non-fan high-temperature oven is fine.
The oven will not warm if the clock is not set as the main oven is directly linked to it. You may want to check your wiring to the element you have changed as all elements use the same neutral path, meaning if you missed a wire off (especially if you pulled it out through the oven cavity) or have put them on the wrong tab it won't work. It could also be a duff element (the new one).Let me know if you need any further help.
