Question about Canon PowerShot SD1300 IS IXUS 105 Digital Camera
Canon SD1300 memory card locked
I just got my camera a year ago. I haven't had this problem until this year came. It happened recently. Whenever i'd turn on my camera. It always says 'Memory card locked' ...I can definitely say that MY MEMORY CARD wasn't locked. I even bought a new memory card for it. I restarted the camera but it still gave me the same message 'memory card locked' .... What should i do?
    New Friend:
There will be a small button on memory card....fix the button on unlock position.
Posted on Mar 23, 2013
  • Canon Master
  • 4,738 Answers
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Posted on Dec 17, 2011
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
Novi doorbell intercom system won't work. Got it about 8 years ago, worked OK except for minor problems until recently. Now it malfunctions constantly. We finally had to disconnect the wiring o
If you are looking for new intercom system then I would suggest you to buy it from http://www.hulksecurity.com/ .Hulk Security System not only provides intercom systems but they also offer variety of access control system, CCTV and alarm systems. Well, I hope this would help you and have sorted the concern for intercom system.
Oct 24, 2012 | Novi Wireless Doorbell Intercom Security...
EMachines 270 rebooting whenever new USB inserted
sounds like you have a short circuit try a diffferant usb port or a usb extension
Feb 11, 2012 | eMachines Computers & Internet
I am using this camera from last 3 years. It was working fine. Suddenly, a problem occurred. Now whenever I select the Auto mode, it is set to video option instead of still image. I have formatted...
I'm have the exact same problem. Purchased the camera 3.5 years ago. Recently needed to shoot a video, when finished I set the camera back to Auto and it stayed in video. Portrait mode shows manual, all other modes work as assigned. I've noticed at least TWO other posters having the same problem within the last couple of months. It's as though this camera (mfg. 2007) has a Trojan program from the factory to make us buy newer models.
Other than resetting, is there a way to flush and reload the firmware?
May 06, 2011 | Canon PowerShot A570 IS Digital Camera
Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
442 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
