yes it is possible. First you can use a partition software. The second is using the disk management tools, these are the steps.
1.To run Disk Management Tool, click on Start,
right-click My Computer, and select Manage from
the menu
that appears.
When you see the Computer
Management window,
click the Disk Management item listed underneath
the Storage
heading. You then see the main Disk Management
pane in
the right side of the Computer Management
window.
2.
Creating the partition:
Unallocated space appears as an Unknown
Partition in the
Disk Management diagram, you can use it to
create a new
partition in some or all of the space. To create
your
new partition, you need to right-click on the
part of
the diagram that represents the unallocated
space, the
unallocated space has a black stripe running
along the
top and then choose the "New Partition" on the
menu that appears. To create your new logical
drive in
an extended partition that has free space
The free space has a light green
strip along
the top, right-click on the free space then
choose New
Logical Drive from the menu that appears. Now
you will
see the New Partition Wizard.
The Partition Wizard will
asks you
to specify the following:
1 The Type -
Primary,
extended, or logical partition. Your hard drive
can contain
up to four primary partitions, or three primary
partitions
and one extended partition. Choose the primary
partition
if you are created a partition in which you will
install
an operating system (this is unusual situation).
Choose
extended if you plan to create several logical
partitions
within it. The logical partition type is
available only
if you choose to create the new partition in an
extended
partition with some free space.
2 The Size - You
may use
the entire available space, or leave room for
more partitions.
The Partition Wizard will displays the minimum
and maximum
size for the partition, this is based on the
space where
it will be stored
3 The Drive letter or path
- Two operating system on your computer. You may
select
any unused letter, but the wizard will offer the
next
available drive letter. To Mount in the
following empty
NTFS Folder, you need an NTFS partition with a
drive letter
on the same machine. You may select the "Do Not
Assign
A Drive Letter Or Drive Path" option, this will
let
Windows assign a letter later, usually the
default drive
letter.
4 The
File
system - The default is NTFS
(recommended),
but you can use FAT32 (not recommended) as well.
Both
NTFS and FAT32 will efficiently utilize disk
space on
large drives.
Note: NTFS has better security
features,
the better recovery capabilities after a major
crash,
and has file-level compression built in. NTFS
will also
give you the option of enable compression.
5 The Label -
Type a name
for the partition, name it something that will
indicating
what you will use it for, data files, my files,
fatboy
one, etc.
I hope this solution was helpful.
