its not under warranty. i want to fix it myself but dont know how to open the bottomof the pen. the area with the tip. so can u help me with that?its not under warranty. i want to fix it myself but dont know how to open the bottomof the pen. the area with the tip. so can u help me with that?
You can't post conmments that contain an email address.
Samsung Galaxy Note 3: S Pen stopped working on screen:
Hello. The S Pen is not powered by a battery per se. The screen on your phone generates a magnetic field. There's a coil inside the S Pen that captures energy from the field to power the pen.
1. Question are your S Pen options turned off? Settings>Controls>S Pen>
turn on Direct Pen Input turn on Air Command turn on Air View etc..
2. it could be the pen tip that is worn out and needs to be changed. Check the tip by pressing it into the pen with your finger.. if you feel the tip going into the pen too far, it's probably the tip that is broken or worn out. Some customers say buying new tips is too much trouble, and getting a new OEM Samsung S Pen made for your Note 3 is a safer option.
3. it could be the wacom digitizer screen that is having problems on your phone and needs to be fixed. If you had fixed the screen prior, it could mean the person who installed the replacement screen could have did a bad job.
4. if you are using a magnet closure case, try taking it off and then using your S Pen. Because the external case magnet can interrupt the magnetic field the S Pen uses for power rendering it useless, until you remove the magnetic closing case.. and then all should be well again.
5. You can do tests on Note 3's that are not carrier locked by dialing *#0*# (this is not a solution but it can help eliminate possibilities)
6. If you bought an Aftermarket knockoff S Pen, that's probably the problem right there. A lot of non OEM Samsung S Pen's have their own issues and work for only some things.
7. You can try fixing the sensitivity of the S Pen
8. Buy an original Samsung Galaxy S Pen. A Note 1, 2, 4, or Note 5 S Pen will work for your Note 3, but it may not fit inside the Note 3's internal compartment/holder. You can try buying a used one to save money, but be aware that you might have to change the tip
? 4:04
https://www.youtube.com/watch?v=lHPRyDgGErY
Feb 1, 2015 - Uploaded by Aaron Rutten
I recently got a new tablet because my old one was broken. ....you find that you have lost pen tablet pressure sensitivity this will fix the problem: ...
c if u have virus in ur pen drive u will get the information like this... 'A' drive is incorrect r whatever which will show windows cannot support this file... so u plse try to format ur pen drive....
have u tried re-installing the driver...
if thats the case even if u tried different pens it wouldnt work... plus even if ur driver was fine a different pen wouldnt work for that driver...
after re-installation if the pen still doesnt work then theres a 50% chance ur pens not working...
One more thing does ur monitor support it???
I found a solution before asking help from c-pen support.
1. Uninstall C-Pen software
2. Remove C Technologies entries from registry. They appear in HKEY_CURRENT_USER\Software and HKEY_LOCAL_MACHINE\Software 3. Reinstall C-Pen software (remove the pen from USB before reinstalling)
I have a G-Pen 340 which i just bought and the pen isn't being registered on the computer. The green light isnt even flashing :( I dont know whats wrong with it.
