The washer starts 1 min in it starts beep and f 6 code comes on the screen
F06 is an error code that meansthat the control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz1goJUbb8i
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
