Classixx 1200 WAE2416SGB/08 lights flashing on and off machine does nothing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
SOURCE: BOSCH 1200 EXPRESS CLASSIXX ALL RINSE SPEED
bunged up theres a new word does that mean that you took off the pump and cleaned out the hoses as well as the pump yet the lights are still flashing on your unit please message me back with your answer and any further questions you may have thanks again Rick
p.s this also would mean you have cleaned the drain hose line that goes from the pump to the outside of the machine and tested the line to assure that water is flowing out of the drain line in a steady stream of water I await your reply Rick
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
