With TV off, red light blinks 7 times / when TV is turned on, it blinks 6 times. TV is only 4 years old.
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Can you tell me how to fix the problem listed below?
I have the same problem with my sony KV-36HS420, the standby light blinks six times and the TV keeps shutting down before the picture comes on.
I have the same problem. I can fix it my self. I need to know which is the circuit that needs welding?
I have the same problem. I need to know which is the circuit that needs to be welded, I can do it myself.
Standby light flashes six times with TV on
will not stay on light blinks seven times
I'm getting a 6 blink diagnostic code when the unit is on and 7 blinks when the unit is off. You can hear the unit power up when turned on but then shuts off after a few seconds. If I unplug the television for about 6-8 hours without reattempting to plug it back in to test it, it will turn on and work normally when plugged in again.
Yep it blinks 7 times off and 6 times on. When it comes on then it is only sound for a few seconds then it shuts itself off and does the 6 blink thing. No picture at all.
