Emachines W3052 Gets stuck on logo screen when starting up.
My computer does a similar thing, the issue with mine is the mother board which requires everything to be at a certain temperature. Let it run on the start screen for a couple minutes and hit the reset button. If it doesn't boot up you're going to have to get more involved with your PC. Turn off the power, unplug the cord from your power supply, open the case, look for the battery and the JP8 (CLRTC) jumper. Move the jumper from pins 1-2 over to 2-3, wait 30 seconds, and move the jumper back. Close the case, plug in the power cord, turn on your machine, and boot it up. If it still fails to boot check that all cables are securely attached (inside and out), check that the RAM is securely seated, and check the CMOS battery to be sure it is not dead. Beyond this you're looking at a component failure and should contact a repair tech.
P.S. if you feel up to it and can't wait for service, pull the hard drive out of the first computer and use it in a different computer. Be sure to unplug the hard drive from the second computer.
