Installing digital timer and when I follow wiring diagram, the switch clicks and the lights flash on/off when the switch is 'on.' The only thing I am confused about is fact that wire that feeds the actual lights is not visible in box. It must be wired from somewhere else. Coming out of wall I have black, white, and ground. According to diagram I wired black to black, green to green, and red and white from switch to white from wall.
Timer is wired wrong.
Following link has step by step:
http://waterheatertimer.org/How-to-wire-timers.html
Howto wire timers
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: I have the Woods 59018
Open following link to identify timer, read wiring instructions, and download on-line manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
How to wire timer
1) Timer-green-wire connects to bare ground
wire.
2) Switch has 2 wires. Take switch wires and connect to
timer-black-wire and
timer-red-wire. Choose either one for now.
3)
In back of electric box are white wires twisted together and covered
with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then
connect timer-white to bare ground.
5)
Turn on electricity, and push timer door which is also the ON-OFF button. If lights come on, timer
is wired correctly. If lights do not come on, then reverse timer-red
and timer-black wires.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
