SOURCE: Zanussi ZSF6160 Water not heating
Mantona, you're on the right track. Your heater terminals are large, insulated and poke through the tub facing downward. To test this, remove one of the wires connected to the terminal, then check OHMS. If this is what you did, you don't have to do that again. Elements rarely fail, the problem most likely resides in the hi-limit thermostat. You know where the element is, now follow one of the wires back toward the control panel. One of the element wires will pass through the thermostat (in series) before going to the control. The thermostat is mounted tightly to the bottom of the tub, touching it to monitor temperature. When you find it, remove one of the wires (there are 2) and check OHMS. You should read ~1 Ohm, if you read infinity, you found the problem. (You can verify your finding by removing both wires from it and connect them together. Then run a wash load to check the heater. Don't leave it in this condition! The thermostat is a safety device and should not be permanently bypassed! If your test of the t'stat proves that it's OK, you'll have to test it with power on and running. I can walk you through this if needed. Let us know how it turns out.
SOURCE: How to replace heating elemant on Zanussi DE6850 Dishwasher
is your water heater set on 120 degres
SOURCE: I have a Zanussi ZSF 6160 dishwasher which is not
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
SOURCE: where is the heating element on a zanussi de6850
remove RHS panel and you will see it bottom right. looks like a round cylinder with wires going into it.
if not heating worth looking at main board as wel for a broken solder joint on heater relay. bit of solder will sort this
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Hi
The issue can either be with the unit not draining properly
or the timer/electronic board itself has gone bad & should be replaced.
First clean the drain hose and the drain pump for any clogs, you can do this by
taking off the bottom access panel. After cleaning if still the issue is not
resolved then the timer/control board has gone bad and needs to be replaced.
Hope this helps...please post back for further assistance.
Daniel
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
lmnbv
