Will not stay on when start button push lens comes out and right back on
SOURCE: The Lens Stuck in extended position on my kodak easyshare v-550
Hi there, welcome to FixYa.
L-83 is a type of lens error. There are a few different types of errors with causes ranging from a broken gears (they're plastic), to sand or dirt getting in the gears preventing them from turning. So, here are a couple things you can do to fix this yourself before turning it in to shop for repair.
1) Get an air compressor and put the nozzle up to the space between the lens and the body of the camera and blow it out real good. Then turn the camera over (lens down) and tap the lens on a hard surface. You may have to do this a couple of times.
2) Press the power button on the camera, and while it's flashing it's lights, bang the side of the camera on the palm of your hand a couple of times. That may free the gear up.
If it's not something blocking the gears from turning, then it could be that the guide pins on the lens may be out of their tracks. If this happens, then the lens will not move at all.
Press the power button and grab the lens, give it a tug and a twist. Don't be afraid of it, you want to manuever those pins back into their tracks. You should hear a click when they fall back into place. If you hear the click, then stop pulling on it. Power it off and back on to see if the lens retracts.
If these three suggestions won't work for you, then you should turn it in for repair. Perhaps the teeth on the gears are getting stripped off, and it's pieces of the gear themselves that's getting trapped in the other gears.
Hope this helps you. Thanks for coming to FixYa.
Rob
SOURCE: The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
SOURCE: where can i get the right driver for my Kodak Easyshare M340?
You can get the drivers here.
http://www.kodak.com/global/en/service/downloads/dln_ekn036196.jhtml?pq-path=14649
Good luck and please rate
SOURCE: I have the Kodak M530 Easyshare camera and
Press MENU, then use left/right to select the Setup tab. Language should be the ninth item on this menu. Select it, and you should see "English" as one of the choices.
Checkout this tip about digital camera error
messages
Lens
Error fix for Digital Camera
heatman101
