Ii forgot the ipad passcode and it is disabled completely how do i restore it it keeps saying enter the passcode on the ipad when i go on i tunes but the ipad is disabled how do i fix it.
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
thank you so much
this is a great and simple solution thank you so much
i tried what you suggested : i turned off the iPad , and held the home and sleep button until the apple showed up , when it did i took my finger off the sleep button , and still held the home button , but nothing happened it went back to the lock screen .
As for the reason for iPad is disabled, it is mostly caused by entering the wrong password five times in a row. If you continue to enter the wrong passcode, your iPad will become unavailable again and time will be added.
If you forget the password of your phone, don't worry. You can restore your disabled iPad with TunesKit iPhone Unlocker.
My ipad tablet is blocked and i forget id and password how can i do to unlock.?help me
IPAD is password disabled. Can't access the Ipad
screen says disabled connect to itunes
Asked to unlock too many times &forgot
Answer that was accepted. Stupid me but
I was trying too hard and did not understand
The refusals or why one was agreed to.
i put a password on my ipad and forgot it now it is disabled I had 3 more attempts at disabling it and failed now its remained disabled for over a week
I like to erase from my iPad
my little brother used my ipad and he didn't know the password and know it disable how to fix it
I plugged my ipad into my computer to download music. It wouldn't download and said to delete backup and try again. I clicked restore backup and then everything was missing. I need to get all my original stuff back. Is that possible?
Forgot passcode and I have no pc
i forgot my passcode on my i pad air that i baught
HOW DO I RESET MY IPAD
i forget its passcode
ipad screen not coming on
i am unable to connect to itunes from my laptop and my son's ipad is disabled. i have his account synced thru my iphone on icloud but i am not sure how to fix with out losing his data? can you help me?
If you forgot the pass code, can you think of anything that helps you remember? Otherwise say bye bye to your ipad
Think hard. Real hard. And when. You think hard, I mean hard. Trolley
