Thomson RCA Bookshelf System with 128 MB MP3 Player, RS2052 Shelf System Logo
A
Anonymous Posted on Dec 02, 2011
RCA RS 2052 will not recognize cd in the cd player
Won't play any disc on any of the 5 slots boom box also has casette player that records
Laser is either dirty, so a lense cleaning disc required. Or the cd transport is kaput. Uneconomical to repair if this is the case
2answers
Rca rs2650 tray wont open and cd wont play
Remove the CD tray the drive motor and gear is joined by a belt. I used a matching rubber band it works. Most of these drive motors. have a belt for safety. Important to replace the CD tray at the same location for line-up with your CD player drive. If you can get couple manufacturer belts do so. The belt is little tougher than the rubber band. And clean all your moving parts gently .
My rca rs 2764 system the cd player wont open
Hi, what makes a CD player not ejecting or not opening is because the Sim tray which carries the CD inside the player when inserted is damaged and it's not performing it suppose to. o weak to function, You will need to replace the Sim tray that allows the CD go in and out...
Have a nice day...
2helpful
I have a RCA cd player model RS 2663. It has access to radio and cassette player. The cd's stick and it does it with all of them if I change the discs. Can this be repaired or should I just purchase...
unfortunately rca sold there audio division a few years back and product support for audio is very limited,i am a tech for a rca svc center among many other brands as well ,and more often than not we run into a roadblock looking for audio parts..
HOW DO I ENTER FREQUENCIES AND SCAN.
Unlike most every other RS scanner, the 2052 has Uniden firmware, and is fully PC controllable. If you have the cable and CD its easy or download the software here. http://www.qsl.net/kd5lmy/software1.htm
If not, download the manual here.http://mirror.bachelorsgrove.com/pro2052/
2answers
CD's won't play in other machines
Your problem is an easy one.....you need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
I wwant to find a manual for Lyra RD 2052 Mp3 Player
RCA Lyra RD1072 MP3 Player
I need a manual for this mp3 could you please send me one .
Thank you nicki
[email protected]
Top Thomson Audio Players & Recorders Experts
SmartAviator
SmartAviator
 Mikey
Mikey
Bob Kirkwood
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
