Try changing the belts that control the cd mechanism. There is one belt on the bottom that drives the cd assembly and two smaller ones in the left and right of unit. One controls the cd eject function the other controls the cd selection option. This particular linear skate cd system needs to have its belts changed otherwise the motors won’t work the mechanism at all.
SOURCE: I need a owners manual for a Sony Mini Hi-Fi
Click Sony Support to download user manual of MHC-GX250
Thanks.
SOURCE: owners manual for a Sony Mini Hi-Fi, component system,MHC-GX250
You can download the required manual from:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX250
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks.
SOURCE: I have a Sony Mini
It is not possible to cheaply fix the problem, that is for sure. It is mechanical failure on the part of the mechanism. Have you tried unplugging it for a good 10 minutes, then replugging it in? As soon as you plug it back in immediately try to eject the cds. If this does not do it you will be forced to basically break open the cd player to get them out :(.
I'm so sorry about the bad news there, hopefully a "reboot" will at least let you eject them out of there
Tim
SOURCE: Hello, I have a Sony Mini
Since this problem occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
SOURCE: CD burned on my computer won't play back on my
you have probles with a driver try to unistall the driver on the cd or dvd burner and automatic it will install the driver the pc will look for the driver on c:hdd if the porblem continue call 956 400 4141 I'm a computer technician send me you info and i will repair you computer problem.
