Bobcat Miller  225 Welder Generator 907209 Or 907210 Logo
Josh Wilkerson Posted on Nov 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is my bobcat 225 not welding hot enough?
Not burning as hot as it should. Motor runs fine.
David Soto
Level 2:
  • Expert 414 Answers
  • Posted on Nov 30, 2011
David Soto
Expert
Level 2:
Answers
414
Questions
Helped
193789
Points
758
If all your settings are correct and still not hot enough probably your fuse F1 is open and need to replace. Check page 42 of the owner's manual for instructions.http://www.millerwelds.com/om/o4434q_mil.pdf
Hope this fix your problem.
Anonymous
Level 2:
  • Expert 92 Answers
  • Posted on Nov 29, 2011
Anonymous
Expert
Level 2:
Answers
92
Questions
Helped
72572
Points
145
Not knowing the full story, i would suggest, as a start, to set the WFS to No5 then set the Volts to No4. try this setting, Test the welding if still to low increase the voltage to No 5, check if it makes a difference, make voltage to No6, by turning up the voltage, you should see weld becoming hotter. let me know how you get on please
Miller bobcat 225 welder will run and arc but will not weld
First thing I would check is a good ground. This is very important. Your ground should always be to clean metal. Metal that is being welded should also be clean. Good Luck Friend.
I bought a bobcat 225 that has been in a shop for 3 yrs.that had dirt dodbers nest all in it cleaned fuel tank got it running no weld or plug powercheck the fuze ok could it be the compasetore
I would make sure the brushes are free in the holder and the collector rings are clean. You can hold fine emery cloth to the rings while it is running.
If this does not work. you mar have to excite the generator. Robert
I have a bobcat 225 starts fine won't idle down or weld .I used machine last week and it worked fine
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjGyfvWt66DAxW9lokEHSNFANkQFnoECBIQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft26195060-bobcat_225_starts_fine_idle_down_or_weld&usg=AOvVaw2InBt2UWM9iWK9Mj15tTtJ&opi=89978449
I have a miller bobcat 225 is lower power while welding, any idea?
First off, check all of your welding cables to make sure they're in good shape, then check for tight cable connections. Is your machine staying at low idle speed while trying to weld? If so, Switch the idle select into the 'weld' position and make sure the high RPM's initiate. Try welding again. Better? Could be a number of things, if not.
Welder won't speed up to weld ?
What doesnt speed up to weld? the feeder? is the wire burning back? are you getting any wire? this is gmaw / wire right? sounds like it may be running slow
I have a 250 bobcat that stick welds just fine but when you go to wire feed and plug in suitcase box wire feed unit wire feeds but it doesn't get hot enough to melt the wire. LF299725
What model of suitcase? Could be the contactor in the suitcase, could be the mig gun. Are you using the CV setting on the Bobcat, instead of CC? Is the Bobcat on the high CV setting and the dial most of the way?
Would like to know how much a used bobcat migwieldier costs?
Depending in the city you are in. Here in N California the average price for the Miller Bobcat 225 is 3,425.00. Try your local Praxair Distribution welding store.
If this was useful please vote.
3helpful
Miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
Top Bobcat Welding Tools Experts
littlewheel
ADMIN Andrew
ADMIN Andrew
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
