Repair manual
Have you tried any of the following? 1. Make sure camera is off, and then remove the batteries and memory card. 2. Close the battery door. 3. Press and hold down the on/off button for 1 minute. 4. Release the on/off button, and reinsert the batteries and memory card. 5. Power the camera on. Next reset the settings of the camera to the factory default. 1. While the camera is on, press and hold the menu button for approximately 10 seconds. 2. The screen should then display the message "Reset settings to default". 3. "Cancel" will be highlighted so move to the right and highlight "OK". 4. Press the SET button once "OK" has been highlighted. 5. The screen will say "busy" while the settings are returned to the default
Power Reset
Settings Reset
SOURCE: My cannon power shot a75
Hello.
Try shaking you camera and listen for any sound and look through the lens. If you hear anything or see anything out of place, that means your lens is broken. It needs replacing.
