Hello
Four digit universal remote codes to check with Duraband TV are:
0189 0135 0157
0153 0254 0458 0217
Direct Code Entry
1.Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
2.Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
3.Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4.With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
i've tried to use all these codes and none of them are working
