If you mean Power, then your psu (power supply unit) has most-likely gone bad. This happens a lot when a computer is as old as this model is. If you have no other choice than to replace the power supply, be sure to use dell in the search, models of this era did not have an opening on the back to accommodate a power (on/off) switch so you must get a replacement that will fit the case and not need an opening where there is not going to be one.
If you meant anything else, you need to explain better.
