Removing links from a 97P144 watch band can be a bit tricky, but with the right tools, it can be done. Here is a step-by-step guide on how to remove links from your 97P144 watch band:
Gather the tools: You will need a small screwdriver, a pair of pliers, and a link removal tool (specifically designed for removing links from watch bands).
Locate the link pins: Look at the back of the band and locate the link pins that hold the links together. These will be small, thin pins that run through the links and hold them in place.
Use the screwdriver: Use the small screwdriver to push down on the head of the link pin, and then use the pliers to gently pull the pin out of the link. Be sure to keep a firm grip on the pin as you pull it out, as it can be tricky to remove.
Repeat the process: Repeat this process for each of the link pins that you want to remove.
Use the link removal tool: Use the link removal tool to push the link out of the band.
Reassemble the band: Once you have removed the desired number of links, reassemble the band by pushing the link pins back into place and securing them with the screwdriver.
Be sure to take your time and work carefully, as you don't want to damage the band or the watch itself during the process.
Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
Step 1
Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
Step 2
Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
Step 3
Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
Step 4
Remove the link from its neighbor and replace one pin to secure the bracelet.
Making the Band Longer
Step 1
Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
Step 2
Push the pin out so the link is detached from the clasp.
Step 3
Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
Step 4
Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
Step 5
Repeat this process if you need to attach more than one link.
Without knowing the type of band you have, I can only say that the links in an expand band can be removed to make it smaller. Now adding more links would require that one would need obtain compatible links.
For this you will need a pair of fine tweezers, a small flat blade screw driver and a lot of patience.
Determine how many links you need to take out by pinching the band while it is on the wrist. Once you know how many you are ready to remove the links. spread the band and you will see that the very end of the links is tabbed. Be careful and fold down the end of the link with your small screw driver. Be careful not to bend anything. You will then need to turn the band over and bend down the tab of the link on the opposite side but right beside the first tab you bent down. Now you will see how the band is held together. If you look into the two tabs you just bent down you will see a small peice of metal connecting the two links. This is a staple. Pull the staple out with your tweezers. Now go to the exact opposite side and perform the same task. The band should now be apart where you remove the staples from each side. Now count down the number of links you want to remove and perform the task again. *Remember that you must do it the exact same way on each side or the band will not go back together. Once you have the correct number of links out the band will go back together the same way you took it apart. When folding down the tabs be sure to use gentle even pressure so you dont over bend them and keep the band from moving freely. I usually find it easiest to use the fla part of the screw driver in a gentle pressing motion.
Remember that this take watch makers and technician a lot of practice. Be patient. If you arent patient or good with very small parts, pop into your local jewlery store for help.
you probably just need a pin to secure the links back together. an authorized Movado retailer will have the tension or screw pins to put the band back together. They can also order additional links if needed. you can find a local retailer on www.movado.com
you would have to either have custom links made or buy a whole new band to be made the links pop out by pins and then shortened placed this way back together
but if you dont have extra links buying longer band is your better sollution cause creating a link or 2 to fits can be costly
