I have the same problem. My Dell AOI 922 will not scan. We purchased our Dell with Vista just over a year ago and have not had to use the scanner until now. The All In One Center is not available under the programs menu which is needed to scan. Help please! Now that our PC is out of warranty we will have to pay for tech support.... frustrating!I have the same problem. My Dell AOI 922 will not scan. We purchased our Dell with Vista just over a year ago and have not had to use the scanner until now. The All In One Center is not available under the programs menu which is needed to scan. Help please! Now that our PC is out of warranty we will have to pay for tech support.... frustrating!
I have the same problem. From looking at some other boards, it seems that there is no driver for Vista.I have the same problem. From looking at some other boards, it seems that there is no driver for Vista.
AnonymousNov 17, 2008
i have a dell 922 that will not scan, even if i hit the scan button.i have a dell 922 that will not scan, even if i hit the scan button.
AnonymousNov 22, 2008
system does not recognize scan function but will print readilysystem does not recognize scan function but will print readily
when I hit the scan button of the 922 printer/scanner I get a window that says searching for scanning applications please wait. And this goes for ever!
I can by pass it by using a short cut, But cannot use it like it is suppose to be
AnonymousDec 24, 2008
My 920 will not scan, I get the message "Searching fdor scanning aopplications. Nothing ever happens.My 920 will not scan, I get the message "Searching fdor scanning aopplications. Nothing ever happens.
After a hard drive re-format and re-installation of printer driver my 922 won't scan anymore. Uninstalling and re-installing driver has not fixed and the solution center is everything but.
AnonymousJan 08, 2009
my dell 922 won't scanmy dell 922 won't scan
You can't post conmments that contain an email address.
Do you still have the Dell AIO 922 Drivers and Utilities CD? If so, you can reinstall it on your new Dell PC with the Drivers and Utilities CD. Although you are able to see this printer in your list, the other components are missing such as the scan and fax options. If you have already reinstalled it using the CD, you should see the All In One Center under the Start Menu/ All Programs/Dell Printers/Dell AIO Printer 922 and the All In One Center should be showing there. You can right click on the All in One Center and select "send to" and choose desktop to create a shortcut or icon on your desktop. Your options for scanning and faxing should be showing here. Hope that helps!
I have a Dell 942, and I also ran into problems scanning. Basically, the Dell "All In One Center" refused to open, and when the printer generates a scan, it tries to send it to that application. What worked for me was uninstalling Microsoft Internet Explorer 7 and 8. Once I was back to IE6, my Dell printer functioned normally. Upgrading to IE7 immediately "broke" it again.
I discovered this after running a repair installation of Windows (a recommended action any time you start experiencing weird problems). I did not have to format my hard drive or lose any data, although some applications had to be reinstalled or re-patched afterward. But the repair install took me back to IE6, and magically, my printer suddenly worked again! When I went to the Microsoft Update site and upgraded to IE7, poof! Dell AIO Center would no longer open, and I couldn't scan.
If this solution is helpful to you, please rate it.
Thank you,
~~Cheryl
Not sure if this is the correct way around, but it worked. Go to Start --> All programs --> Dell Printers --> Dell Photo AIO Printer 922 --> Dell All-in-one center
From here, you can determine and change your scan settings as needed; then click "scan now" (thus by-passing the button on the actual AIO machine). This scanned photos into my picture program so I could email to all the grandparents!
My Dell 922 won't scan. I can't access the All in one center
