SOURCE: lower arm won't spin
the arm only rotates with water shooting out of the angled jets at the end of the arm and these are probably blocked ( i assume it is free to totate manually) take the arm out and run water into the centre hole and this will help push whatever is blocking it to a visible position - usually rice or sweetcorn. you say there are no obstructions in arm but when no water flowing, the blockage tends to slump back into the main body of the arm and out of sight
SOURCE: Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
SOURCE: Very low pressure getting to spray arms
I removed the lower spray arm, and then the filter. I found that there was a lot of buildup under the filter area. I scraped the buildup off. I found that it was restricting the input of water flow to the pump
New Spray arm split around center joint so when it gets hot it opens up spraying water under door
take it back for another
Alan
