The cleaning element fried itself, blithe earl burned from one end to the other. How does the element get removed?
Hi
F2 Error indicates
a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the door
appears to be closing fine then it is the control board that is bad and should
be replaced. Hope this helps...please post back for further assistance.
Daniel
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
wow., thanks. I did not realize that the connectors were that easy to remove.Thanks so much!
