Samsung C5212 Cell Phone Logo
Anonymous Posted on Nov 25, 2011
Ringer ploblem no sound during incoming calls and no sound during receiving
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Nov 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
101
Points
Try using it on speaker phone. i have the same trouble on a panasonic cordless hand set and it only works with speaker phone turned
2helpful
Low volume on incoming calls
remove battery from phone and reinstall after 10 mins... this seems to fix alot of things also go to sound setting a make sure the volume is turned up all the way
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
2helpful
2answers
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Message box says, "ringer off".
Ringer Settings
Handset ringer volume
4 levels (high/medium/low/off) are available. The default setting is HIGH.
1. Press "Menu."
2. Scroll to "Ringer setting" by pressing up or down arrows.
then press the arrow that looks like a play button arrow pointing to the right.
"Ringer Setting"
3. Scroll to "Ringer volume" by pressing arrow down or arrow up, then press the play button type arrow.
4. Press arrow down or arrow up repeatedly to select the desired volume.
5. Press "Save."
(To turn the ringer off, press down arrow repeatedly until "off?" is displayed, THEN PRESS "SAVE.")
Here's the manual:
http://service.us.panasonic.com/OPERMANPDF/KXTG2431.PDF
Please give me positive feedback if this helps you.
Thanks.
2answers
I9+ phone will not receive incoming calls
check and make sure you ringer is set to something but silent.
Jun 04, 2009 • Cell Phones
2answers
The phone does not ring - ringer is off.
firstly read the operations manual for that phone look on how to adjust the settings of your phone it probably sure was indicated there, because the way i see from what you posted it has no internal circuitry prob. it just needed an adjustment.. hope this advice helps... ;-)
Unknown callers wont ring
maybe check on the ringer type for restricted numbers- you can change ringers by all calls, restricted calls, and caller id numbers. your incoming restricted numbers is probably set at none or silent
Ringer does not work on incoming calls
If someone is calling, do you see it on the phone? If so, you may have muted the sound. Try looking for a a button with a music note on the phone. Hold that button for a bit(atleast that's how it works on my phone)
Motorola v3i
you would have to saved the contacts on your phone memory then assign ringer id to them and pics as well.
2answers
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
