Oven does not heat to proper temperature
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
Our oven is an electrical but it has the same problem...
the F5 symbol displays when trying to set oven temp.
lower oven heats up to 350 preset temp, then cycles off a few minutes later. As it goes off...there is a double beep and the word BAKE flashes on the console.
set over at 350 convention bake and oven drops temp and not keep temp
