Amd athlon II with NVIDIA grapics. The machine with the CD sets vertical. Runing windows 7.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off. make sure that your RAM and Cmos battery are securely seated and dust free some motherboards cmos batteries are soldered in you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang also uninstall some unnecessary programs and run the chkdsk utitlity you should have no input while the chkdsk utility is I progress any input might damage your computer then defragment your hard drive
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps you
• HyperTransport 1.0 supporting speed up to 1000MT/s
Chipset
• NVIDIA® nForce 630a & GeForce 7025 chipset
Main Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
Slots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
On-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
RAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
