Uh oh, I just saw this. Is it in the main board 101-108 exts, or one of the expansion boards?
Ringing is set 3 ways, by the switch on the side of the phone, by programming, by features. First, make sure the switch is in the ring position and have someone call you on the intercom. If it rings, have someone transfer an outside call to you. If it rings, try dialing 790 on the intercom to reset station features. If none of this works, It's time to look at ring programming. It's done from the system programming mode at the main phone or from a PC. It's program codes 408-410 or section 3.2 from the Maintenance console.
The last ugly thing is it's a hardware failure.
Carl
SOURCE: Change Extension No's
You have to go to your phone switch, I believe that all Panasonics are modular connectors. Look for a label that will correspond to your extension number. Find your other extension and then unplug and plug.
Cheers.
SOURCE: Hi i have a panasonic KX-TES824 installed with 2
A Panasonic Analog PTS ring sound is not adjustable, however, the cadence is. An outside call rings with a single ring, an internal call is either voice announce or a double ring. The digital phones from Panasonic have either 8 or 30 different tones, but that's a different system.
Carl
SOURCE: Panasonic KX TES824 Using KXTE console
there are two conditions You have to keep:
- call FWD to CO has to be allowed in reg 607 during system programming.
- CO call has to come to extension in DIL1:1 mode.
Mirro
Was that a quesiton?
