Andis 01690 Hair Trimmer Logo
Miguel Ferrer Posted on Nov 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix my wahl senior so it doesn't pull hair
gggg
Level 3:
  • Master 904 Answers
  • Posted on Dec 11, 2011
gggg
Master
Level 3:
Answers
904
Questions
Helped
520589
Points
1791
It could be one of several problems, but the most likely problem is that the blade is too far back. There are two adjustment screws on the the blade -- loosen these a tiny bit, then slide the blade forward (away from the clipper) and then tighten the screws again.
Cut
Try oiling clipers and shave slow and easy
How to repair wahl seniors
you have to explain exactly what you want to repair or better still explain the behaviour
2answers
The clippers tug and pull on the hair rather than cut the hair how can i fix my problem?
Try some lubrication. If you have not got the oil it came with, use a couple of drops of olive oil.
2answers
Wahl designer clippers pulling hair
Oiling blades and sharpen them will help to fix the issue. However several reasons can cause this issues such as the low power, broken blades etc.
https://pakcentric.com/wahl-magic-clip-pulling-hair/
1helpful
2answers
How do I use Wahl hair clippers? How do I know
Hi I have been a hair stylist for 25 years each guard that clips on has a number on them the lower the number the more hair is clipper off start big like a number 8 will leave one inch of hair 7 leaves 7/8 of a inch 6 leaves 3/4 of a inch 5 leaves 5/8 of a inch 4 leaves a 1/2 inch of hair on the head 3 leaves 3/8 of a inch 2 leaves 1/4 of a inch and a 1 is just hair on the Scalp almost bald no days the color of guards are changing so your best bet is go with the size remember to start with the largest one first then you will know what you like the best and you can't go wrong and if you buy WAHL and you not A Hair Stylist You Can Purchase A Good Clipper at Sallys Good Luck
I have had my current Wahl Peanut trimmer for about 8 months. Recently it is "biting me". In other words, it seems all of a sudden the blade is sharp on my skin and has not been so in the past. I...
if you use this peanut trimmer on a daily basis the blade is worn. On the peanut trimmer you can't sharpen them or adjust them, just replace them with a new one. On the other hand if the peanut blade was biting since you purchase it Wahl will fix at no charge.Most likly they will send you a new blade.
I have the wahl super taper with 1-4 attachments. is there an attachment lower than a number 1
Yes there is Wahl attachment is call a 1/2" Manny's Sharpening Have all the Wahl Attachments, Here is the our web page with the attachment 1/2". Wahl Attachment web page
Top Andis Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kolbrun...
NOEL
NOEL
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
