i am too having the same problem currently. i just went to there site & sent them a question. they say they should get back in one business day. give it a try. :)
Then that stick has died, junk it. USB sticks wore out every time you use them, that one has probably reached its end of life.Next time make sure that you have a backup if you store sensitive data on one of them.
Dowload codec Klite pack, via Google, and open the files with that media player, the tv should then pick it up, seeing as its a multi codec reader program, Hope it helps
If there's nothing on the drive you don't already have backed up, right click on it and select format in my computer.
If you need the files off it and do not have backup copies then you can either send it to the pros for data recovery or gamble on purchasing software that may fix it for a little less money.
Let me know which it is and I'll provide you with more details.
clarification!!! clarification..! ..how u putt password? what did u use? ..is it accesible? can u see somthing wen u plug it? does ur pc recongise it? ...cant tell u noth man...u need to answer all these questions....cos right now ur the only 1 that can think bout a solution...gd luck
A SanDisk Cruzer Mini is a memory stick, like a modern floppy disk. Plug it into a USB port (a thin rectangular hole) - it may be at the back of your computer. Your computer should then recognise it and you can copy files onto it.
Dont worry about being prompted, that is an OS option and you may of turned off by accident. When you insert the flash drive into your USB port, does th elight on the drive ligh up? If not your flash drive may of gone bad.
If it does light up, click on "My Computer" and see if it shows up there.
