Pls let me have the dafault password for Linksys wireless router - WRT 54GL. I lost my Manual. My e-mail addresss is [email protected]
my e-mail is [email protected]
please send me a new solution
user name is royjinho
Linksys Wireless--G WRT54G Router
i am a doctor, find mail not opening, trying again & again,replace new password instead of previous,forgotten previous clue.how u can help? its urgent....plz.i am a doctor, find mail not opening, trying again & again,replace new password instead of previous,forgotten previous clue.how u can help? its urgent....plz.
You can't post conmments that contain an email address.
Use an Ethernet cable to connect your computer directly to the router.
Access the web-server "inside" the router.
Login to the router, with the current ID/password.
View the wireless settings:
* SSID
* encryption-level ('WPA' or better, please)
* network password
be sure you detected the wrt..then the SSID and Security Encryption should be matched..the SSID will definitely detected so the Password should be entered.
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data. then do this : 1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable. 2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router. 3. Type http://192.168.1.1 in the address bar of your web browser. 4. Log-on to the Linksys WRT-150N Router with these log-on credentials: Username: linksys (lower-case) Password: admin (lower-case) 5. Click on the "Clone PC MAC Address" tab. 6. Click the "Clone PC MAC Address" button. 7. Click "Save", click "Continue". 8. Click the "Wireless Security" tab. 9. Choose "WPA2 Personal - TKIP/AES" for encrypted security. 10. Enter encryption password (passphrase). 11. Click "Save", click "Continue". 12. Exit the web browser. 13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router. In about 5 seconds, your wireless connection should be up and running.
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data. Then do this 1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte) 2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router. 3. Type http://192.168.1.1 in the address bar of your web browser. 4. Log-on to the Linksys WRT-160N Router with these log-on credentials: Username: linksys (lower-case) Password: admin (lower-case) 5. Click on the "Clone PC MAC Address" tab. 6. Click the "Clone PC MAC Address" button. 7. Click "Save", click "Continue". 8. Click the "Wireless Security" tab. 9. Choose "WPA2 Personal - TKIP/AES" for encrypted security. 10. Enter encryption password (passphrase). 11. Click "Save", click "Continue". 12. Exit the web browser. 13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router. In about 5 seconds, your wireless connection should be up and running.
If you see the reset button our router, just press the button ..this should take the router back to factory default.
Remember any other saved configuration will be wiped out too..
Thanks Ranjit
Well I'm no expert on routers, but I've never heard of Netopia. If you can, try Linksys routers, they're so easy to use and they have the best customer service. I have a Linksys WRT-54GL Wireless Router linked up to a Wireless-G PCI adapter. I wont lie to you, Linksys is very easy to use, and you can see any activity on your network straight from your computer. I got my setup for less than $50.00, but I don't know if they got cheaper or not. They're blazing fast too, they can transfer data up to 54Mbps or higher, I've never used anything quite as simple as a Linksys router, I did have and old Aris router, but it was too difficult to use, so that's when I bought the Linksys. You won't be disappointed!
