Question about Vizio VW37L 37 in. LCD HDTV
Vizio VW37L no power
Vizio logo stays amber in color doesn't come on when power is pushed
    Sergeant:
    Champion:
  • 433 Answers
Check for bad capacitors in power supply, check voltages coming out of the power supply, if voltages are good, bad main board.. Vizio's are notorious for bad main boards.
Posted on Nov 24, 2011
6ya staff
SOURCE:
Flashing Logo/no picture even After replacement of Power Board.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 09, 2017 | Vizio XVT423SV 42" 1080p 240Hz Tru LED VIA...
How do I know if I need to replace the main board?
Vizio TV Repair - How to Install Vizio LCD Motherboard ...
? 6:21
https://www.youtube.com/watch?v=B_ae3f7C3jQ
Feb 20, 2012 - Uploaded by Brady Smith
Learn how to replace your LCD Visio TV motherboard and hear a few facts ... ANYBODY KNOW HOW TO FIX OR WHAT NEEDS TO BE FIXED IF THE ... I have found that I need to replace themainboard in my vizio 42 inch. .... hey, man. can you help me out? i got a VIZIO E3D320VX from ebay brand new.
Vizio 3632-1512-0150 Main Boards Replacement for ...
? 2:48
https://www.youtube.com/watch?v=a_8URZW356E
Dec 6, 2012 - Uploaded by ShopJimmy.com
Top Common Vizio LCD TV problems for bad Main Unit Boards:... To be best prepared to replace the Main Board inside of yourTV, you will need the following ... If you have any further questions regarding your repair, simply post a ... i can see on one of the small black squares (sorry i dont know what they ...
Vizio TV Repair - E601i-A3 Main Board Replacement for No ...
Dec 08, 2015 | Vizio XVT473SV 47 in. LCD HDTV
How do I fix my lcd tv that won't turn on? It does not appear to be the powerboard.
Vizio logo is an indicator that the tv is live n changes to white that the screen is on meaning if no change to white the smps switch mode power supply board ain't switching the mother board....diagnosis is its MOSFET transistors need replacement or the smps board n ya tv will be fine
Sep 22, 2015 | Vizio XVT473SV 47 in. LCD HDTV
I have a Vizio XVT3d474sv. My TCON went bad, only one side of the screen was working. I ordered a new TCON for it. I had been checking over other things and was lightly tapping areas to see if somethi
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Vizio XVT3D474SV 47 in. 3D LCD TV
What is voltage supposed to be for P on pin on power supply?
The power on is usually 3.3vdc, but on some sets it's at 0v to turn on the set, and 5v when the set is off. Your power supply maybe ground activated. If you replaced the main board, then the power supply is your problem
Jun 08, 2013 | Vizio VP422 42 in. Plasma TV
Model Vizio SV420XVT1A will not power up. The Vizio logo is amber, nothing happens when you press the power button.
You will need to have the set diagnosed as there a number of things could cause this. But I would say you're looking at a power supply or main board problem. It is also possible that your key controller (side buttons) is defective. I take it the TV doesn't turn on with a remote either?
Sep 09, 2012 | Televison & Video
Vizio M261VP 26'' LCD TV no picture, logo does not light up
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
May 12, 2012 | Vizio M261VP 26" LCD TV
Vizio in stand by (amber lights) mode on monitor
Does the remote have one power button for on/off .... or, does it have separate buttons ?
Jan 13, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio VW37L 37 in. LCD HDTV Logo
645 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
