Dryers Logo
Posted on Sep 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Amana LEA30AW that is approximately 7 years old. It takes 2-3 cycles to dry. I have checked the voltage at the plug 240VAC L1-L2 and 120VAC L1 or L2 to Gnd. I cleaned the lint from the vent duct and the inside of the dryer. There was minimal lint. I drilled a small hole (5/32”) in duct at the back of the dryer and inserted a thermometer. The discharge temp with the cloths almost dry is approximately 165? F. There appears to be a good air discharge at the wall vent. Any ideas would be appreciated.
Terry Schneider
Level 2:
Novelist:
  • Expert 177 Answers
  • Posted on Oct 02, 2008
Terry Schneider
Expert
Level 2:
Novelist:
Answers
177
Questions
0
Helped
67238
Points
302
Ok your dryer is heating However it sounds like it is short cycling. Between the cylinder and Front and Rear bulkhead are seals. Take a bottom panel off the dryer and flash a light up at the seal area, while you are doing this look in the cylinder and see if you see lite, if you do this is were the air is leaking thru causing your dryer to short cycle.
Replace both the front and rear seals, is a real pain, take your time and you will do fine.
I need to wire up a 3 phase compresser motor, 9 wires wired 480, to change to 240 volt hookup. right now it is wired 3 motor wires to each hot, no nameplate or wiring diagram.
Please verify the existing connections to determine if they fit the "High Voltage" configuration listed below. If they do (and they should), the "Low Voltage" configuration below is then correct for 240.
Jaypug
Low voltage ...
L1---1--6--7
L2---2--4--8
L3---3--5--9
High voltage ...
L1---1 4--7
L2---2 5--8
L3---3 6--9
I WANT TO KNOW HOW TO TEST A WALL SOCKET WHAT SETTING SHOULD I SET IT TO
To check for voltage, select VAC on meter. electric ranges require 240 vac. common to L1 should read 120 vac, same for common to L2. L1 to L2 should be 240vac. Gas range only needs standard 120vac.
2answers
I have a 3 phase 24kw 60 cycles 240 volt vulcan hart el-40 kettle I replaced the heating element ( not sure what its called ) but I don't know which wires go where to the element
Hi, on a 3 phase wiring system, all 3 legs will be the same voltage unless it is the 25 year old 3- phase, which would have what was called the stinger leg which was higher in voltage. As on most any 208/230/240.277 volt 3-phase wiring system, L-1, L-2, and L-3, have the exact same voltage.It does not make any difference on any of the 3 hot Legs where they terminate on this element. If there are 3 termination points on this element, connect any of the 3 conductors to element. Trust me, as I deal with 3-phase daily.If you do have a 4th conductor by chance that you removed, you will need to check with a volt meter to see which 3 have 120 to ground and the 4th will have nothing to ground and would be some neutral. 3-phase wiring doesn't require a neutral. If you have any more questions please let me know and I will help you.This will solve you're question I am positive! Sincerely,
Shastalaker7
3helpful
How do you check to see if the circuit board is working on a unit
open your control area,
check your l1 and l2 conections this unit is usually 220v
the control is this simple
voltage in no voltage out change the board
2answers
What does ''L2'' stand for shown on Kenmore Elite Oasis st?
you can call sears parts service and they can tell you what code means
Drier has stoppd heating. Exposed heating element. Coils not glowing. notice that coil is for 240 v and we are in the USA, on 120 v system. Continuity test of coil causes light to only flicker.
You need the dryer supply voltage to be 240VAC for the heater. Everything else runs off one leg of that or 120VAC L1 (Black)-Neutral(White)-L2 (Red)
L1 to L2 = 240vac
L1 to Neutral=120vac
L2 to neutral = 120vac
Eric
1helpful
Problems wiring Flotec sprinkler pump
L1- L2 doesn't care if blk or red. Make sure there is 220vac (240vac) on the supply wires. If there is there is something amiss with the pump. Eric
GE dryer barely heating
If this is an ELECTRIC dryer, you're supposed to read 120VAC at both L1 and L2. With the cord UNPLUGGED, check the voltage across L1 and l2 at the wall receptacle. You should read a cumulative of 220-240VAC. If you're only getting 120VAC, the problem is at your receptacle, which would explain why the dryer is not heating. The heating circuits and timer require 220VAC, while the drive motor only requires 120VAC. If the power at the receptacle is good, leave the dryer unplugged and check the continuity of the power cord from the end of the plug at L2 to the terminal block at the back of the dryer. You should read a short or 0 ohms. If the continuity of the plug is good, the problem may be a loose connection at the terminal block or a broken wire. If the continuity is bad (open), then it looks like you may have a bad power cord. Please post back if you have questions. I hope this helps you.
Top Dryers Experts
john h
