I lost my remote control for my technika tv Model - X22/14A-GB-TCD-UK and i bought a technika universal remote control but it doesnt work. What do i need to do?
Hello
Three digit universal remote codes for Technica TV are:
000/ 001/ 004/ 005/ 008/ 009/ 013/ 042/ 046/ 053/ 058/ 076/ 105/ 109/ 170/ 174
Four digit codes are:
0031 0004 0005 0009 0051 0053 0105 0109 0170 0000 0174 0001 0008 0012 0042 0058
OK.
Direct Code Entry
1.Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
2.Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
3.Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4.With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search: 1.Manually turn on the device (TV, VCR, etc.) to be controlled.
2.Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3.Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
4.Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
5.Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
technika tv X22/14-C code for a universal remote
Could someone help me wat button do u press before you put the code in
I need a code to work my remote control to a free view+ box
